Hi All,
Out of interest wondering if anybody has had the same issue with their rear view camera guidelines being misaligned? Mine is a 2023 Honda civic sport specifically.
To confirm they were misaligned, parked the car dead on center of a parking space (even measured each side to check distance from the lines was the same), and confirmed the guidelines were too far over to the left/driver side of the parking space (guideline on the left being on the parking space line).
As a DIY workaround I realigned (shifted over to the right) the guidelines in the cars diagnostic mode (hidden menu) and all is fine now. Did this for both the fixed guidelines annd dynamic guidelines. They are now perfectly aligned and accurate 👌
Has anyone had the same issue and re-aligned the guidelines themselves? Debating whether I should also raise with Honda and get them to sort it given it’s under warranty (not sure if it’s the physical rear camera itself being wonky/out of place that caused the misalignment in the first place).
Thanks!
Thanks!
