For 11th gens the sprayers are located on the wiper arms.
Correct. So does that mean it's no longer the old school spray all over. Now it's spray here and the wipers move the water?For 11th gens the sprayers are located on the wiper arms.
Canadian here. The reservoir takes exactly 1 jug of washer fluid.^ I don't mean to rub it in but Canadian cars always get bigger washer reservoirsI'm positive I can put a full jug of wiper fluid into my reservoir.
Sounds about right, I am sure some US models get a smaller reservoir , quite common with other Honda models that equip Canadian vehicles with larger reservoirs to assist with winter conditions.Canadian here. The reservoir takes exactly 1 jug of washer fluid.
(I’ve filled mine twice now)
People are complaining because the wipers only spray on the up stroke. Then it's dry going down and that just smears stuff all over.I have no issues with it…. Not sure why people are complaining?
Read the manual and put the wipers in maintenance mode.Honda engineers fixing a problem that doesn’t exist. Also the fact that I can’t lift up the wipers without scratching the hood edge. Aggravating.
That's probably not good for them, put them in maintenance mode.As far as lifting the wipers, if the car is switched off, you can rotate them freely (in the direction they move when you operate them with the switch lever). Then once they are on the windshield, you can lift them without the arm touching the hood.
I can't agree more. It uses a lot more washer fluid too. After I got the washer low warning light the first time, I put in half jar of the fluid because I want to purge out the one from the dealership. After a couple of sprays, the light came up again. I was on a 600KM trip. I filled in another 1//4 of the jar and the light came on after a couple of sprays too. With any other cars, 1/4 jar can do many sprays and last for a long time. I thought there was a leak in the reservoir. I brought it to the dealership after I got home. They checked it out and found no leak. I could not believe it. They showed me underneath of my car. It was dry. They asked me to monitor the situation.Honda engineers fixing a problem that doesn’t exist.
