1 - 7 of 7 Posts
I recently noticed that the body is quite soft on the rear passenger doors just below the windows. If you look at the attached pic, the area B is softer and will even move when you press on it. But the area A is hard and won't move when you press it. Tried asking the dealer during the first servicing but was told its like this by design. Does any of you experience this too?
Wheel Tire Vehicle Car Automotive side-view mirror
Discussion Starter · #6 ·
Did you get a chance to check out other new Civics on your dealers lot?
That can help to see how normal or not this is.
I’ve yet to try it, I’ll do so when I go past
Mine are the same way.
Yes ...those panels area flexes.
Is it another build quality issue!!
ok thanks, at least I know mine is not the abnormal one
I guess it shouldn’t be a major issue but just curious if it was only evident in my car.
Thanks all!
1 - 7 of 7 Posts
