41 - 55 of 55 Posts
Sorry dropped the ball on you there. I haven’t , but Mishimoto site says 3/8” I can try and measure this weekend if you still want. Been a bit busy
No worries, appreciate the info if you get the chance. Was wondering the length too but maybe I'll just scoop a little spool of 3/8" and cut as needed anyway. I haven't even ordered a catchcan yet lol
2022 Honda Civic Sport 2.0L
Forgive me if this is the wrong place to post this but I have a 2022 Sport 2.0L and I am not sure where to install the catch can. If some one can show in this picture where the inlet and outlet connect to that would be awesome. I understand it needs to connect to the pcv line but does it matter where? The engine layout is different than the Si so I just don't want to make a mistake, thanks again. 1st time Civic owner, love it so far.
Hood Motor vehicle Vehicle Automotive design Automotive exterior
2004 Mazdaspeed MX5 Hi-Mod / 2022 Sport Touring
Nevermind! 2.0L is port injected, catch can not needed
If you can fit one for cheap, it’s still not a bad idea on any car, IMO. Port injected engines do run considerably cleaner, but they’re not immune from blowby. Yes the fuel cleans your valves, but if you’re moving oil and water (condensation) into the combustion chamber, it’s still going to make your plugs and performance not happy. Wouldn’t spend $200 on one, but it definitely won’t hurt anything to add one IMO.
thanks for your input, have you ran one on a port injected car before? how did it run? also where would you connect the catch can in the picture I posted?
I run a baffled one on my built turbo Miata which is port injected. It runs just fine with a sealed can. It does catch stuff so obviously it’s doing its job even on a port car. Not sure I can help with connections on that engine with that pic, but I’m sure someone has a vid on YouTube, look up K20 catchcan
not a k20 but still port injected, interesting results
I mean it's really about catching contaminants that get through, so it will always have a "purpose" and can help on any engine. But turbos cause higher pressures which can cause more blow by of contaminants plus the added build up issues of direct injected engines make it more of a useful addition to the 1.5T models. I don't think anyone is saying don't do it to your 2.0 but rather that it isn't as beneficial
can you look at the picture and tell me where the inlet and outlet goes? thanks for your input
41 - 55 of 55 Posts
