21 - 40 of 64 Posts
I can confirm the hatchback hybrid can't fit a spare.(at least without losing cargo space) Honda has two different spare tire panels for the hatchback. Those that don't have the spare from factory have a shallow spare tire pan which also lacks the spare tire mounting hole
The shallow pan is maybe 1-2 inch deep at most.
I know FL5 (type R) owners have used the FK8 spare tire which also comes with the raised rear panel. Do be aware the FK8/FL5 uses different lug bolt patterns compared to regular civics!
Wow! I am glad I did not get a hatchback!
Spare Me
$104 for the Honda kit 06421-T38-A11
$116 for the tire 125/80R17 Continental
$15 to mount the tire
Best for me is having a full size spare, second best is having a temporary spare.
Finally had the tire mounted today. No balance, not needed for low speed temp. tire.
Planned to get a Haida brand spare & save some money. The supply dried up.
Too many unrepairable flats in the past.
Discussion starter · #27 ·
Got the kit today $20 to mount tire without balancing so total was around $300. It's worth it for my piece of mind I'll still carry the fix-a-flat stuff too and give it first shot if it ever happens again.
I'm a little confused as to what car/year this is for as you never said. Is it for a 2025 Civic Si (as you elsewhere said you own one)? If so, does the Si normally come with this large spare tire wheel wheel and a bolt hole that this spare can bolt into, yet there's no option to get a spare when you buy the car (only a fix-a-flat kit)? Also are all the 11th gen Si's the same way?
Discussion starter · #29 ·
I have a 2025 Civic Sport Touring hybrid sedan. There was no option for a spare but you can buy the entire kit from the parts department at the dealership and it fits in the well just fine however it is my understanding that this is not the case for the hatchback. I have no idea about the Si as I don't have one.
Kit is for Si, it fits Sedan Hybrid due to shared floorpan Si and Hybrid Sedan.
I don't own Si. It's been reported the kit does not work for Hatchback.
Tire sealant kit is standard equipment on Hybrid and Si.
Dealer was unaware of availability of the kit. Dealer had no clue it would fit.
Spare Me
Thanks for this breakdown. I’m wondering why would others buy the Modern Spare brand when the OEM kit + the tire costs less than the Modern Spare?
That indeed, is a mystery...
Can I ask where you bought the tire itself?
Has anyone tried their new 06421-T38-A11 on the wheel to see if its all good? I’m about to order one but all online Honda parts websites that I contacted are saying it’s not a fit and there’s no part for the hybrids. I’m thinking they’re just checking their databases and saying no fit, if they don't see it in their list of vehicle's VIN?
Discussion starter · #40 ·
Has anyone tried their new 06421-T38-A11 on the wheel to see if its all good? I’m about to order one but all online Honda parts websites that I contacted are saying it’s not a fit and there’s no part for the hybrids. I’m thinking they’re just checking their databases and saying no fit it they dont see it in their list of vehicles VINs?
I haven't actually mounted it but I went out and took some measurements. The distances between the lug holes and the diameter of the wheel with tire are identical to what is on the car.
21 - 40 of 64 Posts
