Where do you order the silencer things?
Ahh now I remember your car from a different thread. Looks great and when I finally swap out my stock wheels/tires I'm going to look into the Anovias. I'm not a huge fan of the 18x9.5 38 offset which is popular with this car. 20lbs per wheel is a nice weight as well!
No, for all practical purposes I don’t scrape. I drive all over Missouri and Arkansas. My front bumper, the HPD pieces, are totally pristine. Ground clearance is good.I want mine to sit like this so bad. So you got the D2 10th gen springs and shocks and struts? And it sounds like you need a silencer as well. Besides the little black plastics rubbing any other rubbing ? Just don't want to be that person scrapping all over the place.
Yep, tenth gen D2 springs with Truhart Shocks and struts.I want mine to sit like this so bad. So you got the D2 10th gen springs and shocks and struts? And it sounds like you need a silencer as well. Besides the little black plastics rubbing any other rubbing ? Just don't want to be that person scrapping all over the place.
Alright I'll order that when I finally decide on dang springs 🤦🏻♀️Yep! I'd get 2 packs of the Large and 2 of the medium.
once i throw some camber arms on it i think itll look a lot better. the camber is aggressive on the back with no armsNah, in fact the car is lower in the rear from factory. Plus take into account the rear fenders are a bit wider, and added camber.
True true. Currently waiting on purchasing some white lines for myself too.once i throw some camber arms on it i think itll look a lot better. the camber is aggressive on the back with no arms
Do you have to take off the spring to put them on? Or do they just kind of slip over the top?
Scroll down towards the bottom. You will need 2 packs of the large and 2 of the medium.
No-super easy. Jack the car up which releases tension on the spring and makes them accessible. Takes 2 min a side.Do you have to take off the spring to put them on? Or do they just kind of slip over the top?
Fronts would require the large ones and the rear the mediums. They have different diameters F-R.Which size would you recommend for just springs?
