The specs of the HPD Civic Si Race Car are still blowing my mind. I just wish they let us know about the power numbers! That Borla exhaust seems to make a big difference based on the sound from the video Honda shared.
Honda Performance Development (HPD) will debut the prototype for a new turn-key, race-ready version of the all-new 2022 Honda Civic Si, which features a turbocharged engine and 6-speed manual transmission. Created, developed and tested in-house by HPD engineers, the HPD Honda Civic Si race car draws upon HPD’s extensive production car and race vehicle engineering experience, including the development and incredible success of the 10th-generation HPD Civic Si TCA race car program.
Built from a body-in-white for SRO TC Americas, amateur touring car series, club racing and dedicated track day use, the race car foregoes a sunroof, sound proofing insulation, underbody coating and seam sealer to reduce weight and aid in roll cage installation. The car is then specifically modified for racing using a selection of HPD, and other performance and safety components.
Founded in 1993, HPD is Honda's official North American motorsports company and the technical operations center for Honda's high-performance racing programs, with products supporting multiple levels of motorsports, from karting to IndyCar, IMSA and SCORE off-road racing.
Modifications
SupplierPart
Drivetrain
HPDPerformance-tuned production-based ECU
PWR / HPDHigh-capacity aluminum radiator
CustomHigh strength 4th-gear set
Cusco / HPDRacing limited-slip differential
Borla / HPDTurbo-back dual-outlet exhaust
Chassis
Bilstein / HPDInverted double-adjustable dampers
EibachRace coil springs
HPDFront camber plates with caster inserts
SPC / HPDCamber-adjustable rear upper arm
RV6 / HPDRear toe adjust arm
MomoEtna 17 x 8 wheels
Pirelli245/620-17 DHH racing slicks
Wilwood6-piston Superlite race calipers
Wilwood2-piece slotted floating rotors
PagidRacing brake pads
HPDStainless-steel braided brake hoses
Body / Exterior
HPDRace body-in-white
HPDRoll cage
HPDBumper-mounted brake cooling ducts
HPDFront, side, rear underbody spoilers
APRRear wing
Interior / Safety
HPDDriver and passenger footrests
OMPQuick disconnect aluminum steering wheel
OMPRacing seat with HPD seat mounts
OMP6-point racing harness
IO PortRacing window net
OMPOn-board fire suppression system
AiM TechnologiesMXP main display
MotecC125 center dash logger
HPDOptional passenger seat installation
Tire Vehicle Car Sky Wheel
Tire Wheel Sky Vehicle Car
Wheel Car Vehicle Sky Tire
Vehicle Automotive tail & brake light Automotive lighting Hood Light
Tire Wheel Hood Motor vehicle Automotive tire
Vehicle Car Speedometer Wheel Light
Vehicle Steering part Motor vehicle Steering wheel Automotive design
