1 - 14 of 14 Posts
Есть перегородка, которая, если она не была снята с вашего автомобиля, должна быть соединена резиновым шлангом и крепится к передней левой колесной арке (за пластиковым подкрылком).
[/ЦИТИРОВАТЬ]what is this item called? what is she for?
22 Civic Si PRL intercooler & charge pipes 27Won DP & FP Ktuner w TSP&Phearable tune
It is a baffle to keep the car more quiet. It is not required for the car to run, though you will want to plug the hole or you will be unable to build boost. PRL sells a kit to plug the hole, if you cannot find the OEM baffle and hose.
Tableware Corded phone Automotive design Hat Serveware
Это перегородка, чтобы сделать машину более тихой. Не обязательно, чтобы машина работала, хотя вам захочется заткнуть дыру, иначе вы не сможете построить наддув. PRL продает комплект для затыкания отверстия, если вы не можете найти OEM-перегородку и шланг.
[/ЦИТИРОВАТЬ]
друг, скажи мне, что этот пункт подойдет?
No I don't believe that will work. You want something like in the link I am providing below. The plug you need for what is in your first post is the black cap. Below is a picture showing it installed. The silver plug is for the baffle up near the filter. I'll include a picture of that baffle below as well.
Here is how it will look with the plug from the kit above
Motor vehicle Automotive tire Automotive fuel system Vehicle Automotive design
And below is the baffle that the silver plug replaces. His right hand is on the baffle.
Hood Automotive design Motor vehicle Gesture Engineering
Here is the silver plug installed
Motor vehicle Automotive design Automotive tire Hood Automotive exterior
What’s the benefit of doing this? Pros and cons.
Normally you just get a bit more intake noise. In his case, it’s a cheaper alternative than replacing the OEM baffle and since the plug kit comes with both plugs, he might as well install both of them.
Достаточно поставить две заглушки и все?
двигатель не взорвется?)
There are not enough spare parts for honda in my country
All the plugs do is cover the holes left when you remove the baffles. The one you are currently missing will prevent the car from building boost resulting in low engine power and throwing engine codes
Discussion Starter · #12 ·
Все заглушки закрывают отверстия, оставшиеся после снятия перегородок. Тот, который вам сейчас не хватает, не позволит машине увеличить наддув, что приведет к снижению мощности двигателя и выдаче кодов двигателя.
[/ЦИТАТА[/ЦИТАТА]
есть ли альтернатива замене OEM дефлекторов?
The only alternative to replacing the factory part would be to find a cap to cover the opening. I'm not sure if they ship to your country but PRL makes the part you need
Discussion Starter · #14 ·
Единственной альтернативой замене заводской детали было бы найти заглушку, закрывающую отверстие. Я не уверен, что они доставляются в вашу страну, но PRL производит нужную вам деталь.
[/ЦИТИРОВАТЬ]
Эта деталь вместе с заглушкой и есть то, что вам нужно?
Gadget Font Automotive design Camera accessory Automotive wheel system
1 - 14 of 14 Posts
