Damn they look good. Would you mind posting where the wires are set up on the fuse, etc.
Sounds good thanks!I need to look under the cabin fuse box. And pop the hood to see where power and ground are. But will do
Hey @SGPkaz, did you connect the 2 wires (not the harness) that came with the fog light to anything?I need to look under the cabin fuse box. And pop the hood to see where power and ground are. But will do
I used fuse 44 the DRL I think that should work but would you know where you connected your power wire? Directly to the battery?No, you can either cut those or leave them tied back. They are for high beam function.
From Mikstore rep:
"The fog has high beam function as well. If you want to enable it, just connect those wires to the headlight high beam wires."
Also, fuse #42 ACC
Where did you connect the positive (white wire)
