1 - 5 of 5 Posts
Car Land vehicle Vehicle Sky Tire
August 31, 2022 — TORRANCE, Calif.
  • 315-horsepower Civic Type R is the most powerful Honda production vehicle ever sold in the U.S.
  • Developed in Japan and track-tested around the world, Type R delivers the best driving experience in the hot hatch segment
  • Beautifully integrated advanced aerodynamics give the new Type R a sleeker design
The most powerful model in Type R's 30-year history, the all-new 2023 Civic Type R is the most powerful Honda production vehicle ever offered in the U.S. On sale this fall, the new Type R delivers the best driving experience in the hot hatch segment, combining class-leading performance with an all-new immersive cockpit experience, and a sleek, muscular new design.
"Type R is very important for Honda as the pinnacle of our factory performance and an irreplaceable brand that enables enthusiasts to experience Honda's racing spirit, and seek the ultimate in speed and driving pleasure," said Hideki Kakinuma, global Civic Type R development leader. "The all-new Civic Type R will continue that legacy, leveraging Honda's racetrack-proven engineering to deliver extreme performance and passion—both on the road and on the racetrack."
The Civic Type R embodies Honda's challenging spirit, with six different designs since its debut in Japan as a 1997 model. Only the second Civic Type R model ever sold in the United States, the all-new and more powerful 2023 model recently set a new production-car front-wheel drive track record at the Suzuka Circuit in Japan, home to the Formula 1 Honda Japanese Grand Prix, securing its legacy as the best performing Civic Type R ever.
Track-Proven Performance
Already a class leader in ride, handling and steering performance, engineers conducted extensive development in Japan, and undertook rigorous testing at racetracks in Japan, North America and Europe to further improve Civic Type R's chassis. This included testing on Germany's infamous Nurburgring, the world's most challenging racetrack, helping make the all-new Type R more responsive, more comfortable and more thrilling-to-drive than ever before.
Under its new vented aluminum hood is an even more powerful version of Honda's award-winning K20C1 engine. Horsepower, torque and response are improved by a redesigned turbocharger, increased air intake flow rate, and a new more efficient exhaust system that features a straight through design and an active exhaust valve. The size, shape and number of the turbocharger's turbine wheel blades have been optimized along with the flow path of the intake charge, enabling the turbocharger to generate pressure in a wider range and more efficiently.
The turbocharged 2.0-liter 4-cylinger engine now produces 315 horsepower @ 6,500 rpm (SAE net) and 310 lb.-ft. of torque at 2,600 – 4,000 rpm (SAE net) – improvements of 9 hp and 15 lb.-ft. Civic Type R is one of the most powerful cars in its class per liter, with a specific output of 157.8 hp/liter, up from the previous-generation's 153.3.
A larger grille opening, bigger radiator and a new large-diameter fan improve engine cooling, ensuring sustained, optimal performance during extreme driving. To further strengthen the driver's connection with the car, the active exhaust valve opens at higher rpm to heighten and enhance the sound of the engine.
Type R's smooth and precise six-speed manual transmission is further improved for an even more intimate and rewarding connection with the driver. A lighter flywheel and a revised rev-match system ensures perfectly paired rev-matching when shifting down through the gears, helping maintain stability on corner entry. The high-strength gearbox has also gained a high-rigidity lever and optimized shift gate pattern for a reassured and hyper-precise gear change. A standard helical-type limited-slip differential puts the engine's power to the pavement effectively.
Now based on the all-new 11th-generation Civic Hatchback, Civic Type R's scalpel-sharp responses and famously addictive driving feel are increased even further by a significantly more rigid body structure that supports both improved dynamics and refinement. The wheelbase has been extended 1.4-inches for a smoother ride and greater stability. Now measuring 107.7-inch, it's the longest wheelbase in its class.
Its front and rear tracks are also significantly wider (+1.0 inches in the front and +0.75 inches in the rear). Together with a retuned dual-axis strut front and multilink rear suspension, these changes improve straight-line stability and steering feel. For exceptional braking performance, Type R's two-piece front brake rotors reduce unsprung weight. Brake cooling is also improved, and a retuned brake booster enhances feel and controllability.
Drivers can seamlessly switch between four pre-set performance settings, selecting different modes for the engine, steering, suspension and engine sound. In addition to Comfort, Sport and R+ Mode, a new 'Individual Model' mode enables customization of the driving experience.
Powerful, Sleek and Sophisticated Design
Beautifully integrated advanced aerodynamics give the new Type R a sleeker, more sophisticated, yet muscular look. Designed with input from aerodynamic development members of the HRD Sakura Super GT team, its exterior is also more aerodynamically efficient, generating more downforce improving high speed stability.
Designed in Japan, Type R's new, more muscular body is 0.8-inches longer, 0.5-inches lower and 0.6-inches wider with broad fenders flared out over wider tracks, and lightweight 19-inch matte black alloy wheels wrapped in wider (+20mm) bespoke Michelin Pilot Sport 4S tires. The new wheels use a special "reverse rim" design that improves the stability of the tire contact patch under load.
All body panels forward of the A-pillars are new and unique to the Type R, including a new more aggressive front bumper design. Its lower stance is accentuated by wider rear doors exclusive to Type R and a reshaped rear bumper that reveals its updated signature three round exhaust outlets. A redesigned rear spoiler with aluminum stanchions and a new rear diffuser intensify downforce and reduce drag.
Civic Type R will be available in five striking colors: historic Championship White-- a Type R exclusive finish revered by Honda enthusiasts, Rallye Red, Boost Blue, Crystal Black Pearl and Sonic Grey Pearl.
Performance Focused Cockpit
Designed to support intense driving experiences, the cockpit of the new Type R enhances the exhilaration of driving with emotive, performance-focused details and features, including Type R's iconic red seats, carpet and trim, a redesigned aluminum shift knob, and a serialized Type R plate on the dash.
The driver sits lower than before in new, lighter, body-stabilizing sport seat, yet with greater visibility courtesy of thinner pillars, relocated side mirror, and a lower hood. New lightweight, heavily bolstered front sports seats with suede-effect upholstery offer both exceptional support and comfort on the track and during long drives.
To better support performance driving, Type R's exclusive new digital instrument cluster features clean, easy-to-read graphics and an extensive selection of displays. The design features a large tachometer and gear-position display, plus a multi-information display.
A second new meter design is exclusive to Type R's +R mode and allows the driver to obtain necessary information instantly, with the engine rpm, and gear position placed at the top. A racing-inspired illuminated rev indicator located above the gauge cluster gives the driver a quick indication of engine rpm during performance driving.
Technology has been smartly integrated into the Civic Type R's new cabin with a focus on the driver, including a new 9-inch Color Touchscreen – the largest touchscreen ever in a Type R – with wireless Apple CarPlay® and Android Auto™ compatibility. Qi-compatible wireless charging and a Bose Centerpoint premium sound system, which was custom-engineered precisely for the interior of the 11th-generation Civic, are also standard.
Exclusive to Type R, a new enhanced version of the Honda LogR® Performance Datalogger combines the Type R's onboard computer and sensors with a new built-in vehicle app. This helps drivers monitor and record a variety of performance parameters in real time when driving on the track or other closed courses, helping to improve driving skills.
Honda LogR® no longer requires a smartphone app, so drivers can use the on-board system or connect to their smartphone for added capability and data sharing. Key features include a stopwatch to record lap times, a tire friction circle in 3D motion that displays the maximum tire force the vehicle can achieve, and an innovative scoring function that helps drivers improve their skills on the track. Users can share their lap times and other data with other Type R owners.
Manufacturing
The new Civic Type R is built at the Yorii Plant in Japan. The Type R's K20C1 engine continues to be built at Honda's Anna Engine Plant in Sidney, Ohio*.
Pricing and additional details on the 2023 Honda Civic Type R will be provided closer to launch this fall.
*using domestic and globally sourced parts
2023 Honda Civic Type R - Specifications & Features
COLORS & TRIMS
EXTERIOR FEATURES
SEATING
COMFORT & CONVENIENCE
AUDIO & CONNECTIVITY
SAFETY AND DRIVER ASSISTIVE TECHNOLOGY
FEATURES
DIMENSIONS
CHASSIS
POWER UNIT
2023 Honda Civic Type R - Specifications & FeaturesTouring
Engine
Engine TypeIn-Line 4-Cylinder with Turbocharger
Max. Boost Pressure23.3 psi
Displacement1,996 cc
Horsepower (SAE net)1315 @ 6,500 rpm
Torque (SAE net)2310 lb.-ft. @ 2,600-4,000 rpm
Redline7,000 rpm
Bore and Stroke 86.0 mm x 85.9 mm
Compression Ratio 9.8 : 1
Valve Train16-Valve DOHC VTEC
CARB Emissions Rating3ULEV50
Honda LogR® Datalogger System
Integrated LED Shift Light Indicator
Active Sound Control (ASC)
4-Mode Drive System (Comfort/Sport/Individual/+R)
Direct Injection
Drive-by-Wire Throttle System
Water-Cooled Oil Cooler
Electric Parking Brake with Automatic Brake Hold
Hill Start Assist
Direct Ignition System with Immobilizer
DRIVETRAIN
6-Speed Manual Transmission (6MT) with Rev-Match Control
1st3.625
2nd2.115
3rd1.529
4th1.125
5th0.911
6th0.734
Reverse3.757
Final Drive3.842
Lightweight Single-Mass Flywheel
Helical Limited-Slip Differential
FUEL ECONOMY
6-Speed Manual Transmission (6MT) (City/Highway/Combined)4TBD
Fuel Tank Capacity12.4
Required FuelUnleaded (91 Octane Recommended)
Adaptive Damper System
Dual-Axis MacPherson Strut Front Suspension
Multi-Link Rear Suspension
Dual-Pinion, Variable-Ratio Electric Power Steering (EPS)
Stabilizer Bar (front/rear) 29.0 mm x 5.0 mm (tubular) / 20.5 mm (solid)
Steering Wheel Turns, Lock-to-Lock2.10
Steering Ratio11.6: 1
Turning Diameter, Curb-to-Curb39.9 ft.
Power-Assisted, Ventilated, Two-Piece Front Disc/Solid Rear Disc Brakes (front/rear)13.8 in. / 12.0 in.
Brembo®5 4-Piston Aluminum Front Brake Calipers
Wheels 19 x 9.5J Matte Black Wheels
Maximum-Performance Summer Tires6265/30 R19
Tire Repair Kit (TRK) with 24-Hour Assistance
EXTERIOR
Wheelbase (in)107.7
Length (in)180.9
Height (in)55.4
Width (in)74.4
Ground Clearance (in)4.8
Track (in. front/rear) 64 / 63.5
WEIGHT
Curb WeightTBD
Weight Distribution (front/rear)TBD
INTERIOR
Headroom (front/rear) [in]39.3 / 37.1
Legroom (front/rear) [in]42.3 / 37.4
Shoulder Room (front/rear) [in]TBD / 56
Hiproom (front/rear) [in]TBD / 48.9
Cargo Volume (rear seat up/down)7 [cu. ft.]24.5 / TBD
Passenger Volume (cu. ft.)99.0
HONDA SENSING® SAFETY & DRIVER-ASSISTANCE TECHNOLOGY
Forward Collision Warning (FCW)8
Lane Departure Warning (LDW)9
Collision Mitigation Braking System™ (CMBS™)10
Short Distance Collision Mitigation Braking System™ (CMBS™)10
Road Departure Mitigation System (RDM)11
Lane Keeping Assist System (LKAS)12
Adaptive Cruise Control (ACC)13
Traffic Sign Recognition14
Blind Spot Information System15
Backing Out Support
Vehicle Stability Assist™ (VSA®) with Traction Control16
Anti-Lock Braking System (ABS)
Electronic Brake Distribution (EBD)
Brake Assist
Multi-Angle Rearview Camera with Dynamic Guidelines17
Tire Pressure Monitoring System (TPMS)18
LED Daytime Running Lights (DRL)
Advanced Compatibility EngineeringTM (ACETM) Body Structure
Advanced Front Airbags (i-SRS)
SmartVent® Front Side Airbags
Side Curtain Airbags with Rollover Sensor
3-Point Seat Belts at all Seating Positions
Front 3-Point Seat Belts with Automatic Tensioning System
Lower Anchors and Tethers for Children (LATCH)
Driver's and Front Passenger's Seat-Belt Reminder
Child-Proof Rear Door Locks
Auto High-Beam Headlights
Bose Premium Audio System with 12 Speakers, including Subwoofer
9-Inch Display Audio with High-Resolution Electrostatic Touch-Screen and Customizable Feature Settings
10.2" Digital Instrument Cluster
Honda Satellite-Linked Navigation System™ with Voice Recognition and Honda HD Digital Traffic
HondaLink®19
Apple CarPlay®20 Compatibility
Android Auto™21 Compatibility
Wireless Apple CarPlay®20 Compatibility
Wireless Android Auto™21 Compatibility
SiriusXM®22
HD Radio™23
1.0-Amp USB Audio InterfaceCenter Console (1 Port)
1.5-Amp USB Smartphone/Audio Interface24Front Console (1 Port)
Bluetooth® HandsFreeLink®25
Bluetooth® Streaming Audio26
SMS Text Message Function
Radio Data System (RDS)
Speed-Sensitive Volume Control (SVC)
Wireless Charger27
Type R Serial Number Plate
Leather 18"-wrapped steering wheel
Sport Pedals
Aluminum Shift Knob
Dual-Zone Automatic Climate Control System
Push Button Start
Power Windows with Auto-Up/Down Driver's and Front Passenger's Windows
Power Door Locks
Driver's and Front Passenger's Illuminated Window and Door Lock Controls
Cruise Control
One-Touch Turn Indicators
Tilt and Telescopic Steering Column
LED Pocket Light
Center Console with Sliding Armrest and Storage Compartment
Sliding Sunvisors
Illuminated Steering Wheel-Mounted Controls
Illuminated Driver's and Front Passenger's Vanity Mirrors
Door-Pocket Storage Bins (front/rear)
Remote Trunk Release
Headlights-On Reminder
Capless Fuel Filler
Map Lights
Rear-Seat Heater Ducts
Floor Mats
12-Volt Power Outlet (front)
Rear-Window Defroster with Timer
Cargo Area Light
Beverage Holders
Exclusively-Designed, High-Bolstered Sport Seats with Red/Black Suede-Effect Fabric and Double Red Stitching
Adjustable Front Seat-Belt Anchors
Adjustable Rear Head Restraints
60/40 Split Fold-Down Rear Seatback
Seating Capacity4
Red Honda "H" Badges (front/rear)
Type R badges (front/rear)
LED Headlights with Auto-On/Off
LED Brake Lights
Underbody Spoiler Kit
Wing SpoilerGloss Black
Aluminum Hood
Center-Mounted, Triple Outlet Exhaust
Smart Entry with Walk Away Auto Lock®
Fin-Type Roof-Mounted AntennaGloss Black
Rear Window Wiper/Washer with Heated Wiper Zone
Security System with Remote Entry and Hatch Release
Variable Intermittent Windshield Wipers
Power Side Mirrors with Integrated LED Turn IndicatorsGloss Black
Body-Colored Door Handles
Push-to-Release Fuel Filler Door
STANDARD EXTERIOR COLORSAVAILABLE INTERIOR COLORS
Rallye Red (R-513)Black/Red
Crystal Black Pearl (NH-731P)Black/Red
PREMIUM EXTERIOR COLORSAVAILABLE INTERIOR COLORS
Championship White (NH-0)Black/Red
Sonic Gray Pearl (NH-887P)Black/Red
Boost Blue Pearl (B-637P)Black/Red
1 - 5 of 5 Posts
