1 - 15 of 15 Posts
Nouseformonkeys
· Registered
2025 Civic Hatchback Hybrid Sport Touring
Joined
Discussion starter · #1 · (Edited)
It’s been six months since I purchased my car so it was past time to for me to do a complete first detailing. I usually do this within the first couple of months of receiving my car but I wanted to get fresh products and a ceramic coating so I had to wait for some slack in my budget to buy all the stuff.
I’ve been just picking product at the local auto parts store lately, but this time around I decided to buy a “system” to clean and protect the car. I went mostly with the DIY Detail line of products including the ceramic coating. It might have been overkill but I also wanted to see how they performed.
I started with the car outside in the driveway.
First, I sprayed on Adam’s wheel and tire cleaner on the w & t and some Meguiars car soap and wheel brushes to agitate and rinsed off. I also sprayed on some old Eagle On Iron Remover that I had still sitting on the shelf. I didn’t notice much color change. Could be because the wheels didn’t have that much iron contamination or that the product is too old and lost its effectiveness.
Next, I used my foam cannon and pressure washer with Griot’s Garage car wash soap. I have a large jug of it so I couldn’t justify buying more car wash soap. When that’s done I’ll get the DIY Detail version. Rinsed it off with the pressure washer and drove it into the garage still wet. This should remove the grit that has accumulated on the surface during normal driving.
I did a rinseless wash with Optimum No Rinse diluted in a bucket with several microfiber towels soaked in the bucket. Used one towel at a time and put it into a second bucket when “dirty” and get another clean towel to continue washing. I did not dry it at this time so it will be used as lubrication for the next step. At this point after two rounds of washing, there should be no grit to cause marring in the paint. I like the bucket o’towels method because you don’t need a second bucket of water that you keep having to dunk and squeeze out to get the grit and dirt off the towel or mitt. And since you’re using a new towel after every panel, there’s no chance there’s some left over grit still on the towel.
Applied the DD Iron Remover and spread it with their “clay towel” to dissolve any rust and pick up any embedded contaminates. I drove it back out to the driveway and rinsed it off with the pressure washer.
Back into the garage to apply the DD Water Spot Remover to dissolve and remove any stubborn minerals on the paint. Back out to the driveway to rinse off again and back into the garage to dry off.
Next step is to polish With DD Gold Standard polish with their waffle foam pad on my trusty Porter Cable Dual Action polisher. Since the paint is in good shape, I didn’t have to worry about getting any damage out. Just a light polish to remove any previous protection from the paint. Wiped the polish off with an ONR dampened towel and then buffed again with a dry towel.
And finally, the DD 5 year Ceramic Coating. The stuff is super stinky. Wipe it on with the included foam pad and level with a microfiber towel and buff with a second “insurance” towel. Don’t want to leave any high spots because it will be a pain to get rid of once the coating sets up.
Oh and I used some Meguiars Ultimate Fast Finish aerosol sealant on the wheels and Armor All Foam Tire Shine. I’m just trying to use up the UFF and the Tire Foam is a spray on and forget process. It leaves a satin finish and lasts a couple of weeks.
I started at 7:30 in the morning and finished at 3:30 in the afternoon with a couple of breaks in between the later steps. Since the car was in the garage after the foam wash, I didn’t have to worry about the sun or the wind blowing dirt onto the paint.
Here are the results:
Discussion starter · #5 ·
FYI...
In a recent test of 19 ceramic spray sealants, the DIY Details product was the first to fail, lasting only a few weeks.
Well that’s disappointing. But this guy was testing the Ceramic Gloss spray sealant that I did not use in my process. Based on your replies on another thread you seem to have some beef with DIY Detail and other THOR related product lines. Perhaps they’re all cookie-cutter assembly line brands with a different scent or colors thrown in to make them look unique. Who knows. That doesn’t mean they are garbage. What’s interesting is the Clean by Pan sealant which is also a THOR clone did better than the DD one. Perhaps Yvan needs to request they update his CG sealant to that formula.
As a detailing enthusiast it’s common to frequently try out different products. There are also those that have their trusty, tried and true brands that they stick with over the years. Other than ONR and Turtle Wax Seal and Shine, I am not loyal to any particular brand or product. And perhaps “loyal” is a bit too strong of a word. I’ve been using those two regularly over the years but if I try something else that I like better then I’ll switch to that. I’m trying out DIY Detail products for fun. If they don’t work then I’ll move on.
I don't have a "beef" with DIY Detail and have no affiliation or real interest in the brand.
I bring it up only because the THOR brands have been a hot topic in the detailing community recently, as there's been a lot of fallout from their lack of transparency in marketing/promotion.
It doesn't surprise me that DIY and Clean perform differently. Pan's product is $24 while DIY Detail is $20, so they made a choice to differentiate the two and position Pan's as a more premium product.
It's surprising the comparable Quivr product is priced at $30, so it's presumably a higher end niche positioning.
Discussion starter · #7 · (Edited)
You don’t have a beef with the brand but you made comments about it on another thread and then you tracked down this thread to post a random video showing the poor performance of one product from the line that I didn’t even use. Actions speak louder than words.
As I’ve said, I was curious to try this brand out. So far it’s left a positive impression. If the durability isn’t there, then I won’t buy again. No biggie.
1) I made comments in that other thread because DIY Detail was specifically suggested/recommended, and it was relevant to point out the oddities with that brand.
2) You will notice in that thread, my posts were mysteriously DELETED! I assume THOR asked the moderators to remove them in order to keep their business practices under wraps.
3) I didn't "track down" this thread and I didn't post a "random" video. I read this thread discussing DIY Detail products when you first posted, and it's the most relevant place to post a test of DIY Detail, since they are suppressing my posts in that other thread.
I agree it's no biggie. You should be free to share your impressions of the brand, and I should also be free to share info about the brand.
But as you can see, someone is desperate to keep information out of the public. Otherwise, they wouldn't have felt the need to delete my rather inoffensive/innocuous posts.
Discussion starter · #9 ·
That is suspicious indeed. Strange that these forums are so far removed from the detailing space that someone associated with THOR would even notice it. It’s not like this is a detailing focused forum.
Agreed!
I'm not trying to spam multiple threads with this information, but DIY Detail / THOR are obviously intent on keeping those facts out of that other thread.
Not surprising at all.
THOR an many other companies use systems/applications to scour the internet for key words and mentions of their brand(s).
This company is in the midst of having their business practices exposed, so they are apparently extra sensitive to keeping the information under wraps, enough to have my mild posts scrubbed.
Discussion starter · #12 ·
I don’t get it. As I mentioned in the other thread, they actually had a YouTube video where they were explaining how someone can contract with them to start a product line. Isn’t that being transparent?
Here’s the video. I didn’t watch all of it but I got the gist of it.
I also posted a video about how they do contract blending and such
THOR's white label/blending services is not what they are lying about.
It's that multiple social media personalities supposedly started their own separate/independently run brands (DIY Detail, CLEAN, Quivr, Detail Co, ect).
But the fact is, all of these brands are actually owned and run by the same entity (THOR).
So these YouTube creators (with their 'separate' detailing brands) create content cross-promoting all the other THOR brands, without disclosing that they are on THOR's payroll and the brands are all owned by THOR. THOR also pays other YouTube channels to create positive content about these brands, again without disclosing the connection to THOR.
THOR should have just acknowledged creating 'partnerships' with these YouTube creators, though that would have caused these individual 'brands' to lose credibility & sales, as consumers would likely view them as re-labeled versions of the same products.
Does that make sense?
Discussion starter · #15 ·
Got it. All these detailing YouTube channels and “influencers” promoting and cross promoting THOR products does feel a bit sleazy. If this is true then I’m disappointed. You watch these guys on YouTube and you assume they are being “honest” in their opinions but if they’re just shills for some large company then that trust is broken. A lot of these YouTubers started off by reviewing all sorts of brands and if they’re now just doing a dog and pony show for THOR then I’m done with them.
I will thank you for this post now before the evil THOR overlords get it taken down.
1 - 15 of 15 Posts
