21 - 38 of 38 Posts
So not the same but I can say that I'm not a hybrid fan. I purchased an '07 Civic hybrid because I drove 200 miles a day, 5 days a week for 5 years. The first battery pack went after roughly 200k miles/(5 years) costing $3200 + labor and get this, they charge me freight for getting the battery so after tax this is a $4k replacement. Then at around 289k/(10 years after replacement) battery pack is shot again. So in the end, you end up paying more IMO.
Did they give you the option not to replace the battery but just remove it and have a non-hybrid?
Hmmmm. What I read about hybrids (Honda, Toyota) electric motor initially moves a car and then ICE starts. So unless somebody does some software patching hybrid without battery will not move at all. I might be wrong but that is my understanding how 'modern' hybrids work.
After 200k miles don't you think you are due for a new car? I understand you might like that particular car and it might be very reliable but still... And it is a lot of driving... you are spending your life in a car. What a life...
They don't use phones, happily. 5 and 2 years old.
Keep it that way but it will not last long. As soon as they go to school they will see what other brats have and will ask for one.
Hopefully you will be able to train them properly to stay away from idiotic social networks and other garbage on Internet. All the best!
Depends on the implementation, the older Honda Insight didn’t work in that way I believe. Depends on the car, there’s definitely some cars I would hold on to for life and 200k isn’t a ton of mileage to everybody, it just depends how often you drive and what kind of driving you do and your preferences.
Discussion starter · #25 ·
thanks, and yes that's the goal. One day, they'll get their own and I get it, but I will delay that as much as I can. There's a lot of positives about modern society and connectivity, but I feel like it's overshadowed by too much soul-sucking social media.
car forums and DIY hubs are cool tho. One of the good things internet has brought.
Dealership said that car will not continue to run if the hybrid battery pack completely fails. I ended junking the car in April since the battery pack replacement was 3x the blue book value of the car.
My point was that in my situation, a hybrid did not save a dime in the long run. I've been averaging 14 years on holding onto my cars, the replacement was a '24 HR-V. Still have an '09 Pilot in excellent condition :)
Hopefully ~17 year difference means battery packs are built better and hybrids are more reliable?
I’d argue that over the long term a 2.0 hybrid will be less problematic than the 1.5 turbo. The ICE runs at low loads and with decent oil changes will literally last forever. Battery packs can be rebuilt for cheaper than a full replacement, and the rest of the hybrid components are perfectly stout and can be replaced with used parts if needed (and safer than buying a used replacement turbo for example).
For example on my old Prius the battery pack consisted of 27 smaller cells wired in line. Instead of replacing the entire pack, if you walk into a hybrid shop (with cash in hand of course) they can measure the cells individually, and then replace typically 1-4 weak cells in the pack and it costs a fraction of a full pack replacement. I was told by a local shop something like $500 was their typical cost of rebuilding a pack, vs $2000 + labor to swap in a remanufactured one.
I looked into repairing or rebuilding the hybrid battery on a friends 15 year old Camry. It's not as simple as it seems. There may be only two or three bad cells but you can't just replace them there is a whole balancing routine that has to be done and while there is a ton of DIY info out there it takes some equipment and quite a bit of time. There is a whole underground community of old Prius owners who are fanatical about this stuff. So I was turned off on hybrids until I drove this Civic. I just saw a lot of positives in the complete lack of belts, starters, alternators, turbos and gobs of power with a highly under-stressed engine. I made the leap and I guess we'll see. I've only had the car two months and already there's a recall but it appears to be a relatively minor issue (steering) So far I am very happy with it and I've done a lot of road trips through all conditions outside of foul weather. Just did a trip from San Francisco to Las Vegas and back over 10k foot Tioga Pass and across -283 foot Death Valley and got 50 mpg!
They really should have been building hybrids in a way such that when the battery fails, it can be removed and act as a traditional non-hybrid ICE. Obviously this isn’t really possible with the new civic since it’s an eCVT, but some hybrids were built with a traditional transmission such as the older mild hybrid Insights which even came with a manual transmission.
already there's a recall but it appears to be a relatively minor issue (steering)!
HA! Finally Honda admitted issue with steering!!!! Yeah... after months and months of customers complains on Honda forums... and dealers playing stupid (as they are!). I can bet with anybody, when I do next test drive dealer would have NO CLUE regarding this recall and will claim Civic Hybrid has no issues whatsoever.
I do NOT consider this issue as minor. How would you feel if you try to lightly steer left or right and car suddenly lurks like you try to do left or right turn???
I believe you're describing a "parallel hybrid" system, where the motor does most of the work and the electrical system assists. If battery dies, motor can still move the vehicle. On the other hand a "series hybrid" is only electrical motor drives the car forward.
Series favours the city, while parallel favours the highway.
The civic is both, which means we get an efficiency and torque advantage at low speeds and high speeds. We also have the advantage of not having a transmission, which is one less point of failure and less maintenance.
IMO these advantages outweigh the risk of a battery failure. In this case the battery pack is also tiny, and different from a pure EV battery pack. It is by design less likely to fail and more likely to last many years (see ancient Priuses on the road)
This, by itself is total nonsense. Civic has NO GEARS. Wheels are moved either by electric motor or ICE (at higher speed and there is NO gearbox). Why they use eCVT to describe transmission is beyond me. I guess they could not come with short and meaningful name...
Well technically there is a transmission though not in the sense that it would have different selectable ratios. For anyone who really wants to know exactly how the thing works I suggest watching this video by Prof Kelly at Weber State University. He explains the whole thing with actual parts on a bench.
Understanding the Honda E-Drive
Here’s how I look at it. Honda warranties the battery for 8 years/100,000 miles. By that time the car will be well paid off and I could afford to replace it.
Worry less, drive (and enjoy) more!
21 - 38 of 38 Posts
