Hey guys, what are my options for fixing this? I tried running hot water and trying to pop it out but it was difficult since there's a undercarrage plate and I'm trying to use a small hole beside it to insert an object.
I’ve fixed these with a little bit of heat and light pressure from the inside. After applying the heat, start from outside of the dent applying light pressure and work your way through the dent. It helps a lot if you have someone applying the heat in a sweeping motion while you work underneath.Hey guys, what are my options for fixing this? I tried running hot water and trying to pop it out but it was difficult since there's a undercarrage plate and I'm trying to use a small hole beside it to insert an object.
