Mikstore Model C power folding mirrors with integrated LED turn signals, 2022 Si.
14K views 38 replies 13 participants last post by  mickjaggah
I added the power folding mirror with integrated LED turn signals to my 2022 Civic Si. I had previuosly posted that I added the power folding mirror kit from Mikstore. It wasn't a fun install but it was cool to have the stock mirrors fold and unfold with the locking and unlocking of the vehicle, but I always wanted the integrated LED turn signals. When Mikstore offered the Model C, plug and play complete mirror kit, I jumped on it. A little spendy at over $700 US, but well worth it to have the LED turn signals with heat, BSM and power folding. I am jumping in to share the install with you folks, in case you are nervous about attempting the install, and to provide relevant directions for the North American Civics. My install was in my 2022 Honda Civic Si that already had Blind Spot Monitoring and heated mirrors, but may assist others with other 11th Gen models. The instructions provided by Mikstore were a little confusing, so hopefully what I attach will take the confusion out of the install.
Everything provided was OE Honda, and literally pinned in to the factory connectors, except for 2 wires that required tapping, which was super cool. It is so OE that after the install the folding mirrors show up in my settings on my center mounted dash display allowing me to turn them on or off through my head unit, again, super cool.
#8 ·
I ordered the Model "C" complete kit from the Mikstore for $650 US, and the mirror caps for another $82 US also from the Mikstore. I have the American spec Si, so I had to order mirror caps with the addition of the LED turn signals. Mikstore sells the caps in Type R red, black and carbon fiber. I appreciate the concern from others in this stream, but I have never had an issue with my dealer on my mods. This kit once installed, can be super stealth, especially at the doors, since you literally pin Honda terminals into existing connectors. Other than the instructions provided by Mikstore (which were super confusing) the kit is OE and amazing. I went through the car wash and my mirror bumped one of the drier nozzless. My mirror simply closed electronically, and one push of the fold/unfold button and it was right back. Originally, I added the folding mirror kit form Mikstore to my Si, and they worked great, but taking the mirrors apart, cutting the harness and then soldering it back together after the motors were added was a lot of work, and then I still didn't have the integrated LEDs. Nearly plug and play of the model "C" kit is well worth the money. Everything but the wiring carried a Honda part number.
Mikstore is super helpful if you hit them up on Facebook Messenger. The time zone difference can be a pain, but they will always respond, and they want you to succeed.
The PDF that I attached here, I also provided to the Mikstore, so you may see it again if you do business with them.
#14 ·
Love it. I appreciate you posting the write up. I'm too cheap to buy the kit right now, but this info is perfect. I'm considering buying the mirror caps with light cutouts, the sequential LEDs (and wiring them to be constant) and making my own harness. I'm curious if the non-LED mirrors have any kind of mounting area for the turn signal unit or if I'll have to get creative.
#16 ·
I took my old non-LED mirror apart and there is no provision inside the mirror to mount the OE LED strip. I assuming that the lower exterior portion, under the mirror cap must carry a different part number as well as the mirror glass frame. I ordered black mirror caps for my Si (catching a lot of crap on the red ones). When I pull the red cover off of the LED mirrors I'll add photos of what's going on in it, to see the differences.
#15 ·
I have my old mirrors still. I can pop off one of the covers and see if the plastic inner frame is set up to accept the LED turn signals. It's been a while since I took them apart to add the motors to non LED mirrors. I'm pretty sure the inner structure is different between LED and non-LED, but I'll look, and let you know.
#18 ·
No problem. I know aftermarket is tempting at times, but the Mikstore Model C kit mirrors are 100% OE. Everything has a Honda part number.
A little spendy for the Model C kit, but the quality is certainly there, and the ease of having them provide an LED mirror that already has the folding motor installed was worth it. Especially after already doing the motor install on the non-LED mirrors (a real pain in the butt).
If you can find a deal on OE LED mirrors from a Touring on eBay or something, you could get the motor kit from Mikstore? Adding the LEDs to the US Si will still require modifying the wiring harness of the donor mirrors and picking up switched positive input from the connector above the fuse box so they flash, but it's doable if you're willing to do the work.
#23 ·
If you are looking at the Mikstore kit to add motors to your current mirrors then there is quite a bit wiring to do, as the motor only kit doesn't pin in like the complete kit. It has a separate harness and control box and requires running a wiring through the firewall grommet behind the brake pedal to the battery, as well as across the cabin. If you purchase the complete kit with the motors already installed (like I did) then you are correct. All of your connections would be inside the doors, pulling signal from the locking mechanism inside the door to trigger the motors at lock and unlock. The kit also comes with a driver's side door window switch with the folding mirror button sourced from the Pilot. The passenger door comes with a new window switch as well. The window switches have the same part number as the ones in my car, but I swapped them anyway (maybe they did something inside the assembly before shipping IDK) The wire that travels across the cab is for folks that are adding LED turn signals to the complete kit.
#27 ·
Sounds like you purchased the motor only kit? I had purchased the motor only kit and installed it in my non-LED mirrors and used the aftermarket control box. When Mikstore started carrying the complete kit, I ordered it for the ease of installation. I simply didn't want to crack the mirrors back open and deal with it. Both kits that they sent me contained the correct mirror control switch (sourced from a Pilot, I imagine). Both switches that they sent me were spot on for my 11th Gen Si. I don't know what the A-Spec mirror control switch plug looks like or the control panel on your driver's door?
If you install the mirrors and wish to eliminate the goofy plug-and play control box, it may be doable, but as I mentioned before the window switches, they sent for the driver's and passenger door in the complete kit carried the same part number as my car, but I don't know if they went into them and added jumpers inside the switches? I'm guessing they did, or they would not have provided them, of course they are serving several markets and trim levels, so I really don't know. I added the new switches on my install. As a note, I had no issues with the plug and play set up in the 6 months it was in my car, so it was reliable.
If you have an Acura, you may need to source the mirror control switch from the MDX, if what they sent you won't plug into your mirror switch connector?
For an 11th Gen Honda, in your situation, like a Touring with BSM, Heat, and LED turn signals, simply pinning a jumper from slot 14 on the white Mirror control switch back to slot 20 on the gray driver's side window control switch would be all you need on the white connector for the mirror control switch (it is a green wire in the photos). Pinning 2 wires from the gray driver's side window control switch, negative in slot 26 and a positive in slot 27 and then using these 2 wires (white and black in the photos) to drive the mirror motor wires from the add the motors kit, theoretically would work. The wires from 26 and 27 would need to go directly to the small 2 pin connector in your kit, and not pin into the white connector that goes to the mirror. Again, I don't know what they did inside the control switches that they sent with the kit. They may have modified them internally to bypass the need for the control box in your kit, so this may not work, but I would try it with jumper wires for proof of concept before pinning anything permanently. Pinning is easy...unpinning is not.
#28 ·
View attachment 16966 View attachment 16967 View attachment 16968 View attachment 16969 View attachment 16970
Awesome, thanks for the detailed reply. For some reason I cannot post pics right now (maybe because I'm new). But whenever I gain that ability I'll post pics of the back of the 10th gen switch that came with my auto-fold kit and the newer switch that I'm fairly sure comes with the C kit.
Ok nevermind. I figured it out. The first pic is the 10th gen switch, and the second pic is the newer switch.
The autofold mikstore kit basically adapts between the 2 pin patterns and wires the mirrors very differently than the C kit does.
#29 ·
Apologies, I spaced your ask on the photo. I have attached a picture of the pins on my mirror switch, and yes, the mirrors work off the switch and can even be enabled disabled at the head unit in settings. Since I only added pins to my existing white mirror switch plug the fit wasn't an issue with the Model C kit. Have you made any progress on your project?
#30 · (Edited)
I've made some progress. I was able to independently source the exact same mirror switch you pictured. I also modified the mikstore autofold harness to wire out the black box as a proof of concept and was able to get it to work.
So at this point I need to take apart the mirrors to install the fold motors, which I kinda dread because I know it will be a PIA. After that I will attempt to wire it in the OEM/C kit manner. The open question is whether my OEM window switches will work. I think they will because I have visually confirmed they have pins in the right places and I have conversed with someone who took a slightly different route than I am taking but nevertheless successfully used his OEM window switches. If all else fails I have the fall back of the modified mikstore harness and 10th gen switch to go with.
At the end of the day if all goes as planned, at the cost of the independently sourced mirror switch I will be able to wire the autofold kit exactly like the OEM/C method and avoid the necessity of fishing a wire across under the dash between the doors, which will be worth it in my book.
#32 ·
On the bright side, since you already have the Integrated LEDs in your mirrors, the mirror caps are much easier to take apart than the non-LED mirror caps. When you start to pry the mirror caps, do it with the mirrors still on the car for leverage (same with removing the mirror glass), and start prying right above the LED strip. Be patient, lots of subtle wiggling, and try to use pick tools to get under some of clips as you dissemble, especially the 3 large clips closest to the car window. Once the caps are free, removing the mirror glass becomes easier. The mirror stalk has a 2-piece shroud. Huge pain, but it has to come apart to get to the base screws. Work this with the mirror off the car. The wiring harness from the door to the mirror has to pass through a hole much smaller that the pin connector, (Honda connectors with micro pins, don't like to de-pin) so I peeled back the casing on the harness and cut each wire staggered at 1/2 intervals. After I passed the harness through the new motor assembly with the 2 new motor drive wires, I soldered each wire and used heat Shink tubing. Staggering the wires prevents a lump, like a mouse in a snake and is handy, because, if memory serves a couple of the wires, are the same color. Good luck on the project. It is a pain in the butt, but worth it.
#33 ·
Awesome, thanks again for the advice. I definitely planned on taking the mirror lens and cap off before removing the assembly from the door, and thanks to you I'll attempt to take the cap off first before the lens. I've got some de-pining tools that i've had success at de-pining honda harnesses in the past which I plan to use. In fact, I'll probably just take the door panel off this weekend and practice depinning the mirror connector before attempting the full monty.
#34 ·
2 wires for the turn signal mirrors or for the folding part?
I added the power folding mirror with integrated LED turn signals to my 2022 Civic Si. I had previuosly posted that I added the power folding mirror kit from Mikstore. It wasn't a fun install but it was cool to have the stock mirrors fold and unfold with the locking and unlocking of the vehicle, but I always wanted the integrated LED turn signals. When Mikstore offered the Model C, plug and play complete mirror kit, I jumped on it. A little spendy at over $700 US, but well worth it to have the LED turn signals with heat, BSM and power folding. I am jumping in to share the install with you folks, in case you are nervous about attempting the install, and to provide relevant directions for the North American Civics. My install was in my 2022 Honda Civic Si that already had Blind Spot Monitoring and heated mirrors, but may assist others with other 11th Gen models. The instructions provided by Mikstore were a little confusing, so hopefully what I attach will take the confusion out of the install. Everything provided was OE Honda, and literally pinned in to the factory connectors, except for 2 wires that required tapping, which was super cool. It is so OE that after the install the folding mirrors show up in my settings on my center mounted dash display allowing me to turn them on or off through my head unit, again, super cool.
#36 ·
I’m doing this install and having a difficult time because this is my first experience with wiring. i’m stuck on getting the green 23 wire into the gray plug. How are these pins supposed to go into the plug? I don’t know which way is up. Also, the advice on the instructions of “make sure the plug is unlocked“ doesn’t make sense to me. Can someone give me a hand?
#37 ·
Apologies, I'm not tracking the forum very often. List of honey-dos with landscaping has me busy. The reference to unlocking refers to the little tab on the plug that can be nudged with a jeweler's screwdriver. The locking tab only pops up a couple of millimeters but allows the new pin to slide into the connector until it seats. Basically, allows it to click in. The insertion direction should be locking tab on the wiring connector facing down towards the smaller hole use to release the pin if necessary. After insertion, I use a jeweler's flat tip to ensure that the inserted wire is seated, then a slight tug to make sure it's good to go. Press the locking tab back down, and you're done.
